wheres the fuse for are fog lights ?
Evil and Out
If I'm not mistaken, the fog lights are connected in parallel to the headlights and the fuse is on the passenger side under the hood. The diagram on the fuse box cover shows which one it is.
don't see it my fogs and dash light went out the lights for the radio and tac-speedo etc. everything else works none of the fuses say thay are for the dash or the fogs ?
Check the fuse panel on the lower left end of the dash (at about knee level).
Ldub
You didn't read my reply carefully - I said that the fog & headlights are hooked up in parallel. Look in the diagram for headlights and inspect the fuse - I think it's a 10amp fuse. As for the dash, you have another fuse box on the left side of the driver side dash, open the door and pop the cover, you should see the diagram for fuses.
