I noticed one day on the way to work that they were coming loose. I cleaned the area and used crazy glue. So far so good.
I lost one seal somewhere on the road and other was always gone. I just received 2 new ones from my local dealer (very costly).
I really don't know how they are suppoesd to attach. The seal is a V shape and part of the seal has "teeth" cut out. Could someone help describe or post a pic showing how they are to be attached?
Is the top of the seal supposed to be flush with the top contour of the headlight?
I just polished my headlights and thought I would take care of this while it's on my mind.
Thanks
Ty
Do a search for past threads using headlamp gasket or something similar. I had the same problem with the gaskets in terms of not having a clue how they're supposed to fit. Chopper answered my question in the past so I had to take them off again to put them on correctly. Either way, the headlamp is somewhat of a tight fit so when you put the lamps back in, don't be surprised if the gasket gets pushed out of place. Argh!
