Originally posted by Randy712
Anyhoo, I can't get into the spot where the camera goes! I tried removing the spare, then the retaining clippy things and the nut caps and washers. Nothing budged, or could be budged! How do I get in there??
You have to remove the "half moon" plastic piece on the outside of your rear door, this is where the camera goes. As far as I remember there are two bolts holding it from the inside, so you do have to remove the spare to get to them. There's also some adhesive stuff holding the half moon, so you'll have to pool slightly after the bolts are removed.
2001 Kaiser "The Silver Shadow" VX #841
