Results 1 to 12 of 12
Thread: Passenger door won't unlock (power)
    Feb 2004
    01, Silver, 0603
    The alarm beeps and the drivers door works perfectly. The passenger lock doesn't do anything. I can manually lock/unlock no problem.
    Fuse?
    Feb 2004
    '01 Ebony #0830
    Howzit!
    Have you tried to hit the remote 2 times?
    That's how they normally work... Once for driver's door, and the second time for passenger.
    If that doesn't work...
    No go ovah da Pali any moah...
    LOL!
    Hope that helps!
    SilverBullet75
    Formerly: '01 Ebony VXSTLTH
    Now: '08 Saab 9-7x Aero 6.0L
    '99 Ebony VX #0038
    If you were in a colder climate, I'd suggest that maybe the lock was frozen. It happens occassionally to me here in the Seattle area. Maybe you have an actuator that's gone bad. A test meter and/or a 12 volt power source should help you determine where the problem lies.
    Feb 2003
    2001, Black, VX, 0781
    Does the child-proof setting just lock the passenger window or does it also disable the lock? Worth flipping it back and forth the next time you are in the car to see at least.
    Feb 2004
    01, Silver, 0603
    Everything (windows mirrors, etc) work fine. When I hit the locks from the passenger side, the drivers side locks and unlocks, but not the passenger side. I can hear a slight "click", but the lock doesn't move. I can manually lock/unlock, and I can use the key to lock/unlock. The power (key alarm passenger/drivers side buttons) locks don't work from either side.
    Also, the D on my dash doesn't light up when I'm in drive. P,R,2,L light normally.
    Dec 2004
    '99 VX Astral Silver #0949
    If you hear a click in the door, it sounds like the link arm has fallen out of the solenoid. It should be a simple fix, after removing the door panel.
  1. Power Door Locks Not Working
    By Trap11 in forum VX Troubleshooting...
    Last Post: 08/13/2020, 04:09 PM
  2. Key Fob won't unlock the doors
    By PSINGLEY@AMIMACHINING.COM in forum VX Troubleshooting...
    Last Post: 07/30/2014, 01:13 PM
  3. Need passenger side door
    By pbglas in forum VX Talk...
    Last Post: 09/04/2009, 05:14 PM
  4. Buzzing sound in passenger side door?
    By logan5 in forum VX Troubleshooting...
    Last Post: 07/21/2007, 08:43 PM
  5. Need passenger door glass
    By iamjacksadrenalgland in forum VX Talk...
    Last Post: 09/01/2006, 05:53 AM
