Results 1 to 7 of 7
Thread: VX won't idel or idles fast?
    Unhappy VX won't idel or idles fast?
    My 99 vx has 33100 miles and a few weeks ago it started idling rough and a low rpm's. I have been really busy and haven't checked anything yet, but it is getting worse.It now idles high rpm's 2K+ at first then after warm it won't idle at all.Sometimes the idle will change up and down rapidly.Any ideas on were I what I should check first? thanks for any help
    Jeff
    1999 Astral Silver VehiCROSS #1214
    Good question... My 99 VX just hit 85000 miles and has started doing the same thing. When it was idling too high, it would 'reset' itself if i turned the vehicle off and restarted it. Other than that, I'm avoiding the dealership as long as I can... i don't trust them here.
    ________
    Marijuana vaporizers
    Sounds like the high pressure switch on the power streering or the intake gaskets have begun leaking. Verify all other electical connections (especially to the MAS) first then unplug the wire that goes to the PS switch to eliminate that as the cause (vmag has a better description of it).
    To test for intake leaks, get a can of starter spray and spray around the edges of the intake manifold - if it speeds up, you have a leak and the gasket(s) will need to be replaced - good time to upgrade to a supercharger while you have the intake off!
    99' Astral Silver
    Question
    Intake manifold gasket craked / leaking?
    Live Free or DIE!
    Sounds like a good place to start... I'll check those ideas out this weekend. Thanks!
    ________
    Upload sc2 replay
    2000,black,029
    You can try and check the intake gasket by disconnecting the iac valve on the throttle body and flowing propane around the base of the intake. If you hear the engine gain in rpm then you found the leak. If the leak is internal this won't work. You can also use carb cleaner to spray around the intake, but be very careful if the engine is hot. Could catch fire.
    Andy from Isuzu America
    Talking thanks
    thanks guys it appears to be intake gasket.We sprayed starter fluid around the lower gasket and when sprayed in one spot the motor increased speed and made a spark knock noise.Should I assume the gasket is bad?My dad is an ex mechanic and seems to think that is the problem. So I think I am gonna get the gaskets and replace the bad one. Thanks for the help
    Jeff
  1. Replies: 12
    Last Post: 03/31/2009, 05:03 PM
  2. Big Day is Fast Approaching!
    By Jolly Roger VX'er in forum VX Talk...
    Last Post: 01/31/2009, 01:52 PM
  3. Fast Cars and Fast Jets
    Last Post: 07/06/2008, 11:38 AM
  4. High Idel problem
    Last Post: 01/24/2004, 01:33 AM
  5. How fast can a VX go
    By TucsonVX in forum VX Talk...
    Last Post: 01/10/2003, 12:02 PM
