Results 1 to 7 of 7
Thread: Sudden Drop In Mpg
    Dec 2004
    2000, GREEN, UT,0782
    Sudden Drop In Mpg
    I had my 30,000 mile service at Sierra just before Christmas -- replace PCV valve, lub, oil, diffs, trans, TOD, etc. -- and since I got the car back the MPG has gone from an average of 16 to 13.
    The car is not running rough, no smoke or strange noises, idle okay. Any idea what could have been resete, disturbed, left undone or ? that would cause this drop in milage?
    Thanks.
    Maybe they replaced your new air filter with an old one?
    Nov 2002
    dutchguy has a point in that it may be a more restrictive air filter than what you had before. Also, be sure to check your tire pressure as you may have been running higher pressure and some service-writer decided to make yours all spec. What type of lube did they use for the driveline?
    Dec 2004
    Did they repack your wheel bearings too?
    MPG threads have been popping up all over the place lately. Remember, winter time also calls for altered fuel additives. This damages fuel consumption value a bit. I think we have all been feeling the effects recently.
    Dec 2004
    Quote Originally Posted by VehiGAZ
    Manual says to do so at 30,000 but they said to wait until I have my first break job -- which may be awhile since the front pads are are 8mm.
    Dec 2004
    Quote Originally Posted by Joe_Black
    They put in 32 psi. I don't know the kind of lube but they added LSD to the rear diff Maybe that's the problem. The VX is hallucinating.
  1. Replies: 17
    Last Post: 09/21/2017, 10:15 AM
  2. Sudden Engine Surge
    By DK in forum VX Troubleshooting...
    Last Post: 06/17/2013, 10:40 AM
  3. Help: Sudden strong smell of gasoline
    By twalker920 in forum VX Troubleshooting...
    Last Post: 07/12/2012, 06:23 AM
  4. Sudden (apparently) decline in gas mileage?
    Last Post: 03/11/2012, 08:54 PM
  5. Drop in MPG's
    By crager34 in forum VX Troubleshooting...
    Last Post: 02/14/2011, 07:00 PM
