Results 1 to 4 of 4
Thread: Sheared rear lower shock mount bolt
    Mar 2003
    2001, Kaiser Silver, 0482
    last night while installing my OME 912 springs, I sheared off the right side lower shock mount nut. There is enought left to hold the shock in place, but not bolt and washer to hold it on.
    So, how do I go about fixing this, is there a way to hammer out the old bolt that goes through the bracket, or do I have to get a whole new braket with bolt and cut out the old and weld in the new to the rear axle???
    The lift when great other than this, she's riding high now!
    Mike Skurich
    1969 C3 Corvette Coupe
    1988 C4 Corvette Coupe
    1992 Misubishi 3000GT VR4
    1997 BMW F650ST
    2001 VehiCROSS
    2002 BMW R1100S
    2005 C6 Corvette Coupe
    Are you talking about the bolt that goes through the shock "eye" to hold it in place? If so, you just need to replace the bolt. Should be able to get a replacement at any auto parts store.
    Mar 2003
    No, the lower shock mount, the one in the bracket attached to the rear axle housing, its not as simple as replacing a bolt like the top one is!
    I can't remember if there is enough room behind that bracket to get a bolt through there.
    It's too cold for me to go outside and look. You may have to get a new stud pressed in there somehow -worst case will require cutting off that bracket and welding up a new one.
  1. bent rear left lower suspension arm
    By HuzpazA in forum VX Troubleshooting...
    Last Post: 10/12/2015, 10:47 AM
  2. Struggling. How do I remove the lower rear cladding?
    By Osteomata in forum VX Troubleshooting...
    Last Post: 07/19/2009, 06:33 PM
  3. Lower Rear Cladding for Sale on Ebay Stores
    Last Post: 11/17/2008, 09:40 AM
  4. Rear shock ?
    By AndyC in forum VX Modifications...
    Last Post: 12/04/2005, 02:47 AM
  5. Shock Mount Adapter Interest
    Last Post: 09/19/2004, 03:47 PM
