I was looking for a 1in rear coil spacer online, and found that daystar listed some. when i clicked on the part it showed the spacer for the 94-05 dodge ram 1500 2wd front. is this right and will this work?
Intresting, I would like to know the answer to this as well.
'99 Vehicross - Daily Driver
'93 Wrangler - Tank in Progress
When I get home (@4pm, AST) I'll measure the diameter(s) on the spare springs that I have.
If they match the diameter and "thickness" of the Dodge springs, they'll most likely work.
Also, PM AlaskaVX and ask what kind of spacers he has, I know that he's using them with his 912s.
i have the 1" polyspacers from Independant4X. On their site they are listed for Trooper/VX. All they have to be is the same diamter as the ram coil, and have pretty much the same coil wire (or rod diameter) and it will work. Ill have to check mine, took them off when I went to 912s. I recall finding it on some daystar part carrier's websites, and it was listed for the VX or Trooper. Give the part seller a call and make sure, there are probably several vehicles that one part # fits.
Mike Skurich
1969 C3 Corvette Coupe
1988 C4 Corvette Coupe
1992 Misubishi 3000GT VR4
1997 BMW F650ST
2001 VehiCROSS
2002 BMW R1100S
2005 C6 Corvette Coupe
