Results 1 to 5 of 5
Thread: Rust Around Top of Windshield
    Mar 2003
    2001, Kaiser Silver, 0482
    I am starting to notice some rust around the top of the windshield (small blistering and rust color) emminating from under the top rubber strip. It appears to be the result of when the windshield was replaced by the previous owner, they must have scrapped/gouged the paint and left it unprotected. I keep the VX in excellent shape, but this I couldnt have been prevented or even known about by me till now, it really sucks.
    Has anyone else experienced this, and what would you all recommend as the best course of action to repair it?
    Mike Skurich
    1969 C3 Corvette Coupe
    1988 C4 Corvette Coupe
    1992 Misubishi 3000GT VR4
    1997 BMW F650ST
    2001 VehiCROSS
    2002 BMW R1100S
    2005 C6 Corvette Coupe
    Yep, sounds like a sloppy windshield install. And to be honest, it's not a fun repair. Your bext bet is to take it to a body shop and let them do their magic. To properly fix it, the windshield needs to be removed and the area affected SHOULD be sandblasted, primed, and painted. If the rust is noticeable, then you can only imagine the damage under the weatherseal.
    Trust me, it probably isnt as expensive as you may thinking. It's typically a 1-2 day job. Most of the labor is in the windshield removal and replace.
    Nov 2005
    2001 proton yellow 0959
    Just noticed the same thing on the wife's Proton while waxing this weekend. Initial estimate was $1100.00 IF the windshield is not broken during removal ( that would add $900 for replacement ). Did you have yours repaired, and if yes, how much?
    Mar 2003
    Havent done it yet, man that pisses me off cause the rest of the VX is perfect, no rust. Its just that water sits up there in the seal.
    How much painting is involved in that estimate? I was going to have them obviously fix the resuted areas under the seal, and then paint back 6 inches or so and blend it before it reaches the roof rack rails. And easily stop at the sides at the gutter jam.
    Nov 2005
    Going to get it done right, but expensive. The windshield, headliner to remove the roof rails, spoiler, as well as the antenna mast are all getting pulled to paint the entire roof. 22 hours of labor, should be in the shop for 5 days, goona drop it off on Monday 11/27/2006.
  1. Rust in calipers, etc
    By VXD959 in forum VX Talk...
    Last Post: 06/08/2013, 08:32 PM
  2. Evapo-Rust Mini Review - Clean rust off of small parts
    By twistedsymphony in forum General Tips...
    Last Post: 09/17/2009, 06:27 AM
  3. Rust
    By kimonh in forum VX Talk...
    Last Post: 05/03/2006, 12:03 PM
  4. Rust Solutions???
    By xdfarrx in forum Meets...
    Last Post: 04/21/2004, 07:22 PM
  5. Must stop...rust....help..
    By Whaleboy in forum VX Troubleshooting...
    Last Post: 07/31/2003, 06:50 PM
