Results 1 to 4 of 4
Thread: fluids changed
    2000/blk/vx/0223
    fluids changed
    just had all my fluids change @ a quick lube shop, Now when I drive on the interstate I hear a slight roaring noise coming from the back of the VX, I checked the manual and it says that rear axle needs an additive that I dont think was put in. Could this be the cause of the roaring noise that WASN"T there before the fluid change.And can I get both these fluids @ St Charles isuzu? Any help would be appreciated
    You can purchase LSD Addititive at any automotive store. Try a Kragen/Autozone/Advance/Napa and they'll set you right. It costs about $10 a tube, and you'll only need one.
    If you use the Isuzu brand, you need 2....
    I never knew there was an "Isuzu" brand -should I be using this instead?
    I've been using the Mobile 1 and the Shell stuff.
  1. A weekend of fluids...
    By jeeperkate in forum VX Troubleshooting...
    Last Post: 05/15/2013, 11:10 AM
  2. changing all fluids
    By thedutchguy in forum VX Troubleshooting...
    Last Post: 10/17/2004, 01:08 PM
  3. Fluids question...
    By Cyrk in forum VX Talk...
    Last Post: 04/01/2004, 08:41 PM
  4. Chaging fluids...
    Last Post: 03/05/2004, 12:01 AM
