Results 1 to 7 of 7
Thread: Fiber carbon hood insert
    Apr 2006
    2000 dragon green 0496
    I just noticed the carbon fiber insert on my hood looks a little faded.
    Can I paint it? What kind of paint and will it last or should I do something else to the insert to make it look new again?
    2001, Dragon Green, 1342
    CF hood painting
    I just bought a CF insert from user 'newthings'. He said the orginal clear coat was fading as yours. He took it to a autobody shop and had it prepped and resprayed. I would think if you know anyone in the trade, if you did the prep, they might take it into the spray booth when they are clearcoating a job and lay a few coats on it for you for not much money. The spraying is the easy part.
    Don't forget the 600 grit wet sanding and rubbing compound by hand or machine to finish.
    Roy
    Feb 2004
    2000 Foxfire
    i bought mine second hand, and it is beginning to crack on the edges...any suggestions.
    CF Insert
    Hello newthings. You just won't believe how good that insert I bought from you with the yellow casting looks on my Dragon Green. When we get a sunny day here, will PM some photo's to you. Actually, when color sanding, Sand with 1200 wet in one direction then 1500 wet at 90 degree till the 1200 sanding lines are gone. Can then do 2000 wet at 90 degrees till the 1500 is gone, then machine buff to a high gloss, decreasing the grit till there is no grit.
    Apr 2006
    Rowhard: Send me the photos, I have the dragon green too.
    2001 Ebony 0177
    600!!! Man you like to buff. We start color sanding at 12 or 1500 D.A. at 3000 then put the wool to it (finished with foam)
  1. Installed Carbon Fiber Hood Insert Vinyl Wrap
    By Spyder in forum VX Modifications...
    Last Post: 09/05/2014, 11:17 AM
  2. Replies: 10
    Last Post: 01/04/2014, 03:38 PM
  3. WTB: Carbon Fiber Hood Insert w/ Scoop
    Last Post: 08/11/2011, 03:02 PM
  4. Carbon Fiber hood insert!!
    By hchen in forum VX Modifications...
    Last Post: 12/18/2002, 01:41 PM
  5. Carbon Fiber Hood Insert
    By newthings in forum VX Modifications...
    Last Post: 11/12/2002, 04:03 PM
