Results 1 to 4 of 4
Thread: Window drops
    Arrow Window drops
    Does anyone know how to overcome and repair the window as it drops out of line with the door and you have to push it back inot place for it to close correctly.
    Sep 2004
    1999, Astral Silver, VX, 0938
    Use the Forum Search Tool...
    Dec 2004
    '99 VX Astral Silver #0949
    Quote Originally Posted by VCrossfan
    Sounds like spacing the lift arm to be under the window should fix this.
    If not done soon, the plastic tabs on the window bottom will break from the stress.
    The lift arm regulator is attached to the inside door skin. repeated closing of the door with the armrest handle, pulls the regulator with lift arm out from under the window. Pulling the window in at the bottom, pushing it out at the top, and out of the rubber guide part of the frame.
    Using longer metric bolts (4), use as many washers as needed to line the arm back under the window. You know you have it right when the nylon pad in the middle of the lift arm pushes the glass up. It is half way between the two window bolts that hold the glass to the lift arm.
    I have posted pictures with the washers, in my gallery, you will need to read the posts to get the instructions to go with the pictures.
    It's more simple than it sounds, good luck.
    VCrossfan, why is that little mouse reading my ISP address and browser and computer make and type? You are scaring me 'Big Brother'
    Dec 2004
    BTW: If the window drops, or free falls, when lowering, the plastic tabs on the window bottom are already broke.
  1. Replies: 1
    Last Post: 01/11/2012, 02:45 PM
  2. The dreaded "Green Drops" on the floor
    By Chopper in forum VX Troubleshooting...
    Last Post: 06/24/2010, 05:40 PM
  3. Window Issue - Regulator and Window Strip
    Last Post: 01/13/2009, 11:31 AM
  4. Help!! RPM drops
    By Offroad vx in forum VX Troubleshooting...
    Last Post: 10/13/2007, 12:02 AM
  5. Goodyear Shop Drops Elise off a Lift!
    Last Post: 11/14/2006, 07:36 PM
