Results 1 to 2 of 2
Thread: Hello Group lifting question.
    Mar 2006
    2000 White Ironman 0160
    Hello guys,
    I am a new VX owner and was thinking about lifting it 3". I have read a few threads on the subject, but i have not hear of anyone mentioning going to have the onboard computer updated. I was pricing tire the other day. I have the 18" rim and it is difficult to get an off road tire with this rim. the counter clerk said i would need to change the rim size and have the onboard computer updated because of the ABS brake? So I was wondering what steps I need to take if any, or can i just buy the lift kit and the new rim size and tires? If i can go will a 3" lift what size rim and tires should i get? this vehicle is a daily driver too. Interested in your thoughts.
    thanks.
    3" is a lot of lift on a VX. Many have done it, but consider its use as a daily driver. Most drivers so inclined do just fine with 0-2" of lift, easily obtained with springs and a t-bar crank.
    There are a lot of 18" tires out there, just few that neatly fit the 7" rim width that the VX has.
    Most owners will steer you in the direction of the OME 912 lift (search 912 +Triathelete) and the Nitto TerraGrappler tires, size 285/65R18.
    This combo will increase the height of the VX by almost 3" overall, plus the wheelwells will be filled and the truck will get a wider stance. It's both a visually appealing and functional combination.
    As for the "onboard computer," there is no crack for the Isuzu ECU. You'll have to manually compensate for the speedometer error unless you get one of Tone (Monday's) speedo correction gizmos.
    The ABS will survive a 10% change in tire diameter without too much trouble.
  1. Lifting the VX
    Last Post: 02/23/2008, 04:33 AM
  2. Group EGR Question
    Last Post: 11/22/2007, 05:27 PM
  3. Lifting the VX
    By dtruax in forum General Tips...
    Last Post: 01/11/2006, 07:37 PM
  4. Big lifting for the VX
    By wrestler11 in forum VX Modifications...
    Last Post: 10/24/2005, 03:23 PM
  5. Lifting the VX
    By NC_VX in forum VX Talk...
    Last Post: 06/24/2003, 02:47 PM
