Results 1 to 2 of 2
Thread: Brake booster noise
    2001,Ebony,VehiCROSS,1092
    Brake booster noise
    Wanted to see if anyone else has experienced this before I tear into it. Just started yesterday - when you press the brake pedal there is a noise like air rushing out of the end of a baloon you have stretched tight, or like you might hear in a semi with air brakes (not nearly as much or loud, obviously). I figure it's probably a vacuum leak or something has come loose - the brakes work fine. Might mention my ABS light has been on for quite some time (took the bulb out! I hate ABS anyway!), but this issue just started yesterday.
    Anyone have some ideas where to start?
    '99 Blk 0089
    Mine sounded like that but the brake went out completely a day later. Take it to Brake Check and they can verify for sure. If it is indeed the booster, you can get a refurbished one from Autozone.
  1. EBC brake pads and Apex brake lines
    Last Post: 12/14/2011, 02:15 PM
  2. Brake Fluid Leak From Vacume Booster
    By crotchrocket in forum VX Troubleshooting...
    Last Post: 07/02/2010, 04:38 AM
  3. Brake noise? Need advice!
    Last Post: 06/24/2010, 01:56 PM
  4. Recommendations for a Battery Booster / Jump Starter?
    By vt_maverick in forum Chit-Chat ...
    Last Post: 03/22/2010, 12:10 PM
  5. FM antennae Booster Suggestion needed
    Last Post: 12/13/2005, 07:19 AM
