Results 1 to 8 of 8
Thread: outline of tranny filter on tranny pan......
    Mar 2006
    2001 FOXFIRE 0579
    as you may know from my other post, i was under the vx today, checkin things out, and i noticed what i think is the outline of the tranny filter, on the outside of the tranny pan. it was a definately darker brown than the rest of the pan.
    what would do this, (ran with low, or no fluid), or is this a normal thing with you guys too.
    thanks again for all your help
    God bless you all, i know i have been
    david
    Mar 2006
    2001 FOXFIRE 0579
    got a couple of pics
    ok, got some pics.....is anyone elses tranny pan look like this?? havent tried to scrub it off yet.
    Apr 2003
    ex IronMan
    yes, almost identical... just a bit smaler stain and lighter. My drain plug was like that since day one. Does not necesseraly mean running low/no fluid. If they changed your tranny fluid bebore the drain plug might been not too tight ? Changing drain plug/adding copper washer might help....
    Andrey
    1999, Ebony Black, VX ,1976
    there was TSB for the drain plugs leaking. I had mine replaced under warranty. I do not remember if they replaced just the gaskets or the drain plugs too. shawn
    1COOLVX
    Mar 2006
    2001 FOXFIRE 0579
    the "outline" isnt wet....its just dry,slightly greasy, dark, dusty like substance. is it just former leak mixed with dust, dirt, and road stuff?
    Mar 2006
    2001 FOXFIRE 0579
    i should clarify, the outline isnt wet like a current leaking situation.
    thank you for your replies. this has been really bothering me, thinking my tranny is getting too hot, and burning images in pan. appreciating all the input.
    God is Good
    David
  1. Which in-line tranny filter to use?
    By UtahVXer in forum VX Modifications...
    Last Post: 04/12/2008, 01:43 AM
  2. Tranny Filter.Strainer????????????
    By VXNIT in forum VX Talk...
    Last Post: 03/14/2007, 11:17 AM
  3. Replies: 7
    Last Post: 02/24/2007, 10:06 AM
  4. Tranny Filter
    Last Post: 10/28/2006, 08:49 AM
  5. tranny filter change 30k service
    By xiaoz in forum VX Talk...
    Last Post: 01/06/2005, 08:55 PM
