Results 1 to 9 of 9
Thread: My turn to replace a CV boot
    Well I finally managed to tear a CV boot . The drivers side outter is history. I'll let you guys know how it goes. May be tackling it tomorrow with the help of my neighbor.
    2001, IronMan White, #440
    Arrow Ditto!
    Hey Billy,
    Yep, I have to replace my drivers' side CV boot also. I knew I shouldn't follow you on the trails. LOL
    Are you going to just replace the boot or really get into it and replace the whole thing? I think I'm going to have a mechanic do it for me. I've checked three places. All three say I should have the whole thing replaced. That cost anywhere from $510 to $575. One guy told me he could just replace the boot for under $150, but there is no warrenty.
    Peace.
    If your CVs are in good shape you only need replace the boots ($17 at Checker Auto). I think the are seeing $$$$$$$! I am just doing boots unless I find the CVs are bad...they look and sound okay so far.
    Just got back from Checkers. The boots they sell are similar to the Mechatechs. They are silicone type that stretch over the CVs so you don't have to dissasemble the Cvs.
    They are made by Dorman and the part# for the outer is 614-001. The kit comes with the boot, grease and clamps.
    Does anyone know if Mobil1 syynthetic grease is okay for CVs?
    99 Silver 0210
    Hey Tri, Tom and others....How did it go?
    My driver's outer CV boot is shredded and I am hoping to hear that the $17 Checker kit worked.
    Any updates?
    Bim
    '99 Ebony VX #0038
    Quote Originally Posted by Triathlete
    I agree. I've replaced one of my CV boots twice for < $20 and the joint itself was in pristine condition. This time around I'm replacing all four with Mecatech boots and installing diff drop brackets.
    This job is very messy, but not something an adventurous beginner couldn't do by themselves.
    They're still holding up!
    99 Silver 0210
    kpaske/others:
    I have the boot kit from Dorman. Can you give this "adventurous beginner" any tips and advice? Or should I just jump in and scare the h*ll out of the trick-or-treaters with my swearing?
    Bim
    '99 Ebony VX #0038
    There are actually a couple of really good HOW TO's posted on this board and others that show how to get to the CV joints without disassembling your entire axle. You basically need to put one corner on a jackstand while you use your jack to hold the weight of the A-Arm, and you can remove the inner boot and manipulate the joint out of its cup for repacking with grease. From this point you can also access the outer boot if it requires repair or maintenance.
    Here's a beginner's tip for easy cleanup: When you repack your CV joint, just stick it in a plastic baggie and squirt a ton of grease in with it. The plastic will allow you to push the grease around and get it all packed in without making a huge mess.
    If you have any other specific questions, ask away!
  1. CV Boot?
    By PapiGringo in forum General Tips...
    Last Post: 10/31/2014, 10:21 AM
  2. Replies: 18
    Last Post: 06/19/2012, 12:11 PM
  3. Another CV boot question
    By stangri in forum VX Talk...
    Last Post: 01/23/2012, 01:26 AM
  4. CV boot
    By Exclamation in forum VX Troubleshooting...
    Last Post: 11/21/2011, 09:17 PM
  5. CV Boot Covers
    By Green Dragon in forum VX Modifications...
    Last Post: 03/09/2005, 05:14 PM
