Results 1 to 10 of 10
Thread: engine codes?
    1999 silver 1346
    engine codes?
    I went to autozone and am getting 2 codes PO400 and PO440?
    any ideas on what these might be?
    also if i reset the check engine light does anyone know how many miles it resets itself if i want to get an inspection. I was told that after i reset the light a inspection machine will know and wont pass me untill a certain amount of miles have gone by without the light.
    thanks
    adam
    2001, Proton Yellow, #0580
    It took my truck about a week before I could get the codes to qualify after a reset (it depends on the amount of driving you do and not the actual time) - same issue - I was pulling a code for a faulty battery and the reset disqualified me for passing the emissions test.
    -- John
    John Eaton
    Original Owner
    2001 Proton Yellow #580
    Atlanta GA
    "Metaphors be with you"
    1999 silver 1346
    thats what i ment , how many miles will it reset?
    1999 silver 1346
    I was told one of the codes is a egr valve, does anyoine know whrere this is located and is it easy to change myself?
    P0400 Exhaust Gas Recirculation Flow Malfunction
    P0440 Evaporative Emission Control System Malfunction
    heres a link to a list of codes http://www.obdii.com/codes.html
    i dont know details about the EGR valve, but i remember a thread saying it wasnt terribly difficult to pull, but also that a lot of times you could just clean it out and it would be okay, do a search for EGR and youll probably return some good results
    1999 silver 1346
    anyone have any idea what this might be?
    id say the best place to start is cleaning your EGR (exhaust gas recirculation) valve well with some carb cleaner
    http://www.vehicross.info/forums/sho...gr+valve+clean
    http://isuzufaq.ibctech.ca/#faq1
    Feb 2003
    2001, Dragon Green, 1023
    I have this problem now too. After spending $1200 on a major tuneup Fuel System, emergency brake, and engine gaskets, 2 days later my Check Engine light came on again. A friend of mine scanned it for me and pulled the subject line code off. (P0440)
    Does anyone know what this really means and how to fix it? (If needed)
    Thank you.
    Perry
    "If you're not living on the edge, You're taking up too much space...." -Perry Kloska
    Feb 2003
    Nevermind... I did a search for "P0440" and got what I needed... I was trying "P0440 Check Engine Code" and didn't get anything but this thread.
    I reset the light, hopefully it stays off....
    Check Engine light
    My Check Engine light came on recently but I don't know what codes came up but the mechanic did indicate that it was an out of tolerance indication on the O2 sensor. Since it was reading (although out of spec) he didn't think the sensor was bad. He replaced the airfilter and cleaned the MAS (Mass Airflow Sensor) and reset the light. So far (600 miles) the light hasn't come on again.
    BTW - the engine was knocking horribly any time you stood on the gas but the above "repair" took care of that too.
  1. engine codes P0327, P0161
    By pbkid in forum VX Talk...
    Last Post: 04/20/2009, 07:24 PM
  2. Long drives and engine codes....
    By Kenny in forum VX Talk...
    Last Post: 06/27/2007, 04:38 PM
  3. suggestions for engine P1404 and P0402 codes
    By bielsubob in forum VX Troubleshooting...
    Last Post: 01/03/2007, 01:20 PM
  4. Engine Codes?
    By colmhd in forum VX Troubleshooting...
    Last Post: 10/13/2005, 04:12 PM
  5. Check engine - Codes po171, po174, po303
    By Rapp in forum VX Troubleshooting...
    Last Post: 03/27/2005, 09:45 PM
