Results 1 to 5 of 5
Thread: electrical question.....
    Mar 2006
    2001 silver & black VX vin#0438
    I have a question for the electrical gurus out there. I just picked up an easy-to-install alarm I'd been looking for; (has voice response), and eventually I want to install the start-up modification. How do I put it all on one key fob????
    you're a bit short on the essential info !
    Like: what fob? what alarm? how much do you know about the system on the VX?
    Without this I for example are unable to help you out!
    Mar 2006
    electrical question
    Ok, I'll try again.... The alarm is Bulldog #2030 talking model; not fancy. It works strickly on impact and will either chirp or talk. It has a four button remote. I have the standard VX remote that unlocks the door. In the future I would like to install a remote starter. Can all these features be incorporated into one remote, or must I fumble with all 3???
    it is possible to trigger your own alarm throgh the vx unit, but this will mean for you to open the unit and solder some new connections onto the print.
    This is not the sort of work I would encourage someone to do with no experience in this field.
    I think the best option is to remove the original alarm unit and let your buldog unit trigger the doors etc.through the wiring of the vx unit.
    Here is a wiring diagram of this alarm :
    http://wildtoys.com/vehicross/VehicrossAlarmDiag.jpg
    Mar 2006
    Thumbs up electrical.....
    Thanks Dutch for the diagram. I did a little more research and I can get the external starter and my talking alarm on the same Bulldog remote. I can't wait to get started!!!
  1. Electrical issue??
    By Raque Thomas in forum VX Troubleshooting...
    Last Post: 08/22/2007, 04:09 PM
  2. Electrical Question on tools for my VX
    By Francesco Rizzo in forum VX Talk...
    Last Post: 03/05/2007, 10:52 AM
  3. Dead VX, Seems Electrical
    By jbregar in forum VX Troubleshooting...
    Last Post: 09/20/2004, 10:04 AM
  4. Electrical question/problem - HELP!
    Last Post: 09/23/2003, 06:15 AM
  5. Electrical Problems...
    By Jolly Roger VX'er in forum VX Talk...
    Last Post: 08/18/2003, 01:32 PM
