Results 1 to 3 of 3
Thread: Just an Idea.......
    '99 Astral Silver VX -0467
    Just an Idea.......
    http://cgi.ebay.com/ebaymotors/W-Han...70044663QQrdZ1
    Could this be connected to the stock alarm...or even after market alarm system. So that when you unlock the doors and the light on the inside comes on these would come on.
    Nov 2002
    Arrow
    Simple. Just tap the fuse for the dome light and you're done. LED's don't draw much current so you wouldn't even have to use a relay or bump-up the fuse. Route the wires through the existing pathways and under the dash for a neat install.
    definately do-able, i just installed a pair of LED bars under the dash of my buddys A4 that turn on when the doors are unlocked/opened or if the dome light is turned on.. all we did is solder the wires to the top of the pieces that hold the dome light bulb in place then up thru the headliner and wherever you need to go, pretty simple, im planning on doing a 48" flexible LED bar around the cargo area once i get tone's popper kit to get the back door on that circuit
  1. Got any idea what this is ??????
    By slutty22 in forum VX Troubleshooting...
    Last Post: 04/22/2009, 11:29 AM
  2. would this be a really bad idea?
    By Francesco Rizzo in forum VX Modifications...
    Last Post: 07/18/2007, 07:06 PM
  3. Sometimes you get an idea...
    By newthings in forum Austin Robot Technology
    Last Post: 03/25/2007, 05:40 PM
  4. Here's An Idea
    By UNEVEN THOUGHTS in forum VX Troubleshooting...
    Last Post: 09/13/2004, 01:00 PM
  5. Idea for a mod.
    By jayfotos in forum VX Modifications...
    Last Post: 06/20/2004, 03:40 PM
