Results 1 to 3 of 3
Thread: LED Problems
    2001, Dragon Green, 1342
    LED Problems
    Well, leave it to me to have problems installing the LED's listed in the article By Moncha. I went with the towers listed in the article, but I can not get them to fit in the front turn signal lights. They will not go down far enough to turn so they lock in place. The circuit board stops it. Also, with just running the LED's in the back without the Load Equalizers or the Electronic Flasher, they are brighter then with the LQ's. The left side does flasher at a higher speed then the right with the turn signal, but are the same speed with the flashers. Think I will quit while I am ahead.
    2001, Ebony Black, 1153
    yeah
    I put those in not too long ago and had the same problem. You definitely should put the load equalizers in though. It takes quite a bit of force to get those front ones in and they still will not feel like they go all the way in but you can tell when it is to the point that they will not come out on their own. The way that they are made you are correct they just will not completely seat all the way in.
    May 2002
    2000, Proton Yellow, VX, 0584
    The fronts are a little difficult... I worked then in and out a few times and the fit in fine. You HAVE to go with the load equilizers to get the same flash rate as the regular bulbs. To compare on side to the other realy can't be done unless you do a complete side with the equilizer. When all said and done it works, I played with them for so long and finally figured out what I was doing wrong, (Nothing) and just hooked them up and they were fine.
    Scott / moncha.com
  1. Tod Problems !! Help
    By Porschepitstop in forum VX Talk...
    Last Post: 11/17/2012, 12:27 PM
  2. More Problems
    By I_Wanna_Retire in forum VX Talk...
    Last Post: 02/07/2006, 03:54 PM
  3. Problems
    Last Post: 11/28/2005, 03:53 PM
  4. TOD Problems under 30 MPH
    By VR4-Quest in forum VX Troubleshooting...
    Last Post: 08/16/2004, 11:30 AM
  5. A/C problems
    Last Post: 07/20/2004, 01:32 PM
