oil changes
I have run castrol syntec 10w30 since the first oil change on my vx, year round. 93000 miles later I still don't burn any oil, I too have larger tires. Changeing the oil in the VX is a snap. 15 min max. with minimal tool investment (probably 20 bucks). I would advise looking a little deeper for for oil consumption problem though. If all is proper there should be no descernable drop in your oil level if you are changing it frquently. If you are still unsure about how to change your oil and filter get a maintanence manual. almost any similar vehicle will give you step by step instruction. The procedure is the same on any typical truck/suv. the only difference is the location of the oil pan, filter dipstick and layout. step one: drain oil by removeing the bolt in the bottom of the oil pan. allow oil to drain until flow stops. step two: replace bolt. step three: move drain pan under oil filterand unscrew oil filter. again allow to drain. step four: replace filter with new one (hand tight only). step five: fill with oil via the crankcase. cap is locater on front top of the left valve cover but I'm sure you already knew that. I use five quarts. step six: replace oil cap and pat yourself on the back. you have now taken your first step to becomeing a shadetree mechanic, and you now know more about your vehicle than the guys at jiffy lube!!!!
:_drool: It's all fun and games until it can't be fixed!
