Yeah, they're not too difficult. Make sure you read that Planet Isuzu article, and buy some extra screws for the hub nut ring as you will almost certainly strip them. I had to drill a few of mine out they stripped so bad. Like Joe said, you don't need any of the special tools (although a set of snap ring pliers might be nice). The hub nut tool isn't needed as you can use a hammer and screw driver to gently "tap" it loose.
If you've repacked your bearings at 30k, 60k, and 90k like you should have, you should be able to repack again, but if you've neglected them (like I did) you should defintely replace them. Take note of any blue discoloration on your axles where the bearings sit - they can become weakened from the heat of the bearings if they're not properly maintained. Also don't forget to replace your pads with the new rotors. Most long time site members prefer OEM pads. I've tried several premium aftermarket pads and they all seem to wear very quickly. Check out St.Charles Isuzu for a great deal on OEM parts.
If you run into any problems you can PM me as I just did mine a couple of weeks ago. It shouldn't take you more than a couple of hours, but I always start work like that on a morning where I don't have any place to be that day!
