Thanks! Shifter is really easy. Just remove the center console and the plastic shifter cover. Underneath the shifter bezel there is a light assembly mounted to the vertical wall of the shifter assembly that just twists out. You'll see the wire sticking out. This bulb can just simply be removed and replaced with the LED of your choice. It uses the T5 wedge.
