My fiance and I just purchased an Ebony 2000 VX in San Diego a few weeks ago with only 23,000 Miles on it. This morning she called me on the way to work and said the AC wasn't working. The only description of what happened is that the AC turned on when she started the engine and immediatley turned off. The AC button will not illuminate when pressed. Does it sound like it just blew a fuse or is there something else I need to check. Also it has been blowing perfectly fine up until this point. Thank You, Jeff
