Anybody with an OME 912 lift try 315/70/16 instead of 285/75/16 ????????
Shizzle
Shizzle
According to most tire manufacturers recomendations, even 285's are a little wide for the stock 7" rims.Originally Posted by Bimati
IMO you should go to at least an 8", even better 9-10" wide for 315's.
My$.o2.
And a 9 or a 10 is going to be offset waaaay too far and will hit the rear of the fenderwells badly, and a 315/70 is 33.4 inches tall!
To fit those you will need LOTs of trimming and a BFH
Do a search and you will find quite a few posts about fitting 33's on the VX.
Thing is, I have a BFH, and not necessarily the beer cells, er, brain cells to know whether or not to start swingin. I had better read up on the 33's....
Thanks for the input.
