Results 1 to 5 of 5
Thread: VX won't run, park lights stay on...
    2001, yello, vehicross, 4587
    Hi all, new here, bought a 2001 yellow V about 4 months ago, I left it outside and came home and noticed the park lights on, figured the thunderstorm we had tripped the alarm, but the alarm worked fine and would not turn the park lights off.
    here are my symptons:
    the motor will crank but will not start
    the gas guage is not working
    the park lights stay on
    here is what i did so far:
    a known good scantool will not communicate with the pcm when trying to code, gives "err" code
    found two wires under the pass seat that rubbed though to the body, the wires belong to a 3 wire connector that goes to the trans, i assume it is the TOD as when it is unplugged the check light under the TOD display keeps blinking
    the PCM shows no visible short or burnt smell when removed and opened
    ohmed out almost all circuits that I have a wiring diagram for though Mitchell on demand, gonna buy a factory manual to confirm the rest, all check out okay so far
    this is a list of the essentials that i have done so far but have not succeded in changing the problem
    has anyone else had this happen, please email me if you had a similar experience
    Jun 2003
    If you haven't already done so , disconnect the positive battery cable and put a full charge on the battery. While you're waiting for the charge to come up check all fuses in the drivers and engine compartments.
    Aug 2003
    99, black, 1628
    this..
    This might sound retarded, but have u checked 4h to 4l shift lever, it might be stuck halfway between. I remember a couple of times I bumped it when getting out of car, and if I remember right the car didn't start right or something till I put it back in position.
    99 Ebony Black
    The Jersey Fish
    East Rockaway NY
    NYPD's Finest
    May 2004
    99 Astral Silver w/ SC
    The ECM fuse under the hood has given the "crank but no start" symtom to several peeps...with differing side symptoms. Its a 40a fuse behind the battery.
    ----Trans Siberian Orchestra
    I will bet this is an alarm related issue since most alarms lock out the ability to start the car and connect to the parking lights for arm/disarm. Stock alarm or aftermarket? Have it removed from the circuit and test. You cannot simply unplug it though as that will disable starting as well.
  1. Stay Away from Batteries R US!!!
    By Cobrajet in forum VX Talk...
    Last Post: 11/24/2009, 05:03 PM
  2. should it stay or should it go
    By Moonrover in forum VX Talk...
    Last Post: 10/09/2009, 11:12 PM
  3. To park or Not to Park -- or Sell
    By KeithVXlvr in forum VX Talk...
    Last Post: 06/19/2009, 02:39 PM
  4. Round park-n/drive-n lights
    By XCross69 in forum VX Talk...
    Last Post: 01/21/2007, 10:09 PM
  5. WARNING: Stay Away
    By thebear54 in forum VX Talk...
    Last Post: 04/17/2005, 07:26 AM
