Results 1 to 2 of 2
Thread: window reg idea?
    2001 proton yellow #0786
    window reg idea?
    Well, after trying all the window fix idea's i could find on here, none have worked. I've noticed that the plastic guides on the track have a bunch of hairline cracks, and that's were all the flexing is. I'd like to just replace the whole thing. I've found a window regulator from isuzu parts online, but it doesn't have a picture or description. so, does any one know what I'll be getting? is it the full assembly or just the metal track..??
    I don't know if this is same case, but I had similar problem with the window regulator.
    I used WD40, but it made the thing worse.
    Then I used silicon lubricator spray, and it made everything normal.
    I would try it before replacing whole system.
    If this is not your case, just ignore when I said.
  1. late night window idea
    By wetpoop in forum VX Talk...
    Last Post: 03/08/2013, 07:22 AM
  2. Window Issue - Regulator and Window Strip
    Last Post: 01/13/2009, 11:31 AM
  3. would this be a really bad idea?
    By Francesco Rizzo in forum VX Modifications...
    Last Post: 07/18/2007, 07:06 PM
  4. Here's An Idea
    By UNEVEN THOUGHTS in forum VX Troubleshooting...
    Last Post: 09/13/2004, 01:00 PM
