Results 1 to 4 of 4
Thread: Brake light on at startup
    1999 white
    '99 vx (48k miles)
    when i start it in the morning, the brake light comes on for a few minutes, then goes out. it stays off till i park it overnight.
    it seems to only happen from a cold start.
    any ideas ?
    thanks!
    stephen
    check your brake fluid.. mine was doing that and it was low...
    Nov 2002
    Arrow
    As above check brake fluid level and that you're parking on a level surface. Also, your brake light switch may be worn or out of adjustment which could cause contact as the metal expands/contracts with overnight temperature changes.
    My brake light was doing the same thing,
    It was just low on fluid.
    I figured it was going to be the emergency brake switch sticking.
  1. Brake Light Modulator
    By Breezy in forum VX Modifications...
    Last Post: 10/25/2011, 04:32 PM
  2. Brake Light
    Last Post: 11/22/2009, 04:05 PM
  3. Brake light stuck on...
    By isaac65 in forum VX Talk...
    Last Post: 01/19/2009, 08:04 AM
  4. Parking Brake Light
    Last Post: 09/21/2007, 12:34 PM
  5. Brake light on
    By Raque Thomas in forum VX Troubleshooting...
    Last Post: 11/30/2006, 09:59 PM
