went to garage they hadent seen on before could not find point to plug in diostonic computer does any one know were it is?
Yup, directly under the fuse panel by your left shin (or right if your VX is RHD). Might want to use a different garage as that's a pretty common location for the ODBII port on most imports.
found it tucked away,black in colour, thanks,wonder wot the code will be. garage not open till thur. will keep you posted,
