Page 2 of 2 FirstFirst 1 2
Results 16 to 21 of 21
Thread: Drive shaft problem
  1. #16
    2000/blk/vx/0223
    u joints
    both were around 175.00 yes 175.00 probably the most expensive u joints on the planet. bought through St Charles(Merlin) saved 10% compared to my local dealer
  2. #17
    2000/blk/vx/0223
    u joints
    175 through st charles for 2 very expensive part
  3. #18
    WOW!!! That's sick - I think I know a place to find them a little cheaper: http://www.isuzuparts.com/partscat.html
    I have bought a fuel injector from them before and it was very reasonable and a factory quality part.
  4. #19
    Nov 2002
    Arrow
    Quote Originally Posted by tngerman2000
    Wow, that's rich. I got a genuine OEM pair recently for something like $50 each IIRC. Just checked Autozone.com and they list for $10.99 each.
  5. #20
    Oct 2004
    2001, ebony, VX, 0982
    thanks
    but do you guys think that cleaning up that slop in the shaft might solve my vibration problem? do I even need to replace the u-joints to clean up the slop in the shaft? any info would help
  6. #21
    Nov 2002
    Arrow
    That's tough to say. I've personally not had any experience caused by vibration from worn u-joints, it's usually been from driveshaft damage or a balancing weight getting knocked off. If your mileage is up there and the zerks on the driveline haven't been greased regularly then it's a small price to pay for knowing they're new and you'll maintain them going forward. And if you still have the vibration then that part is eliminated.
    One thought: Have you gone down the length of the driveshaft from u-joint to u-joint and given it a good visual inspection?
  1. Front drive shaft
    Last Post: 02/17/2017, 06:02 PM
  2. front drive shaft
    Last Post: 02/01/2015, 11:41 AM
  3. Front drive shaft help
    By cheetah2390 in forum VX Troubleshooting...
    Last Post: 05/22/2014, 03:57 PM
  4. ABS and drive shaft U joints
    By kitman3 in forum VX Troubleshooting...
    Last Post: 10/23/2013, 10:03 PM
  5. Drive Shaft Rebuilding
    By blacksambo in forum VX Troubleshooting...
    Last Post: 12/03/2011, 10:27 PM
