Results 1 to 15 of 21
Thread: Drive shaft problem
    Sep 2006
    2000 Black VX 0223
    Drive shaft problem
    My dealer says I may need to replace my front or rear drive shaft. Does anyone know how much this should cost?
    Nov 2002
    Arrow
    Did they give you a reason to replace the entire driveshaft?
    Sounds more like your dealer is getting ready to give you a lube job. Take it to a driveshaft shop for a second opinion, if there is indeed something wrong with a propeller shaft.
    Please share what symptoms you're experiencing and maybe we can get you closer to the mark and save some grief and $$$.
    Sep 2006
    2000 Black VX 0223
    I have a vibration somwhere that shows up around 50-70 mph. They think it's a drive shaft but they don't know if it is front or rear. They are still checking it out...
    Nov 2002
    Arrow
    That could be acouple things, depending on how severe the vibration is. Tires are a good place to start as it's easy and inexpensive to get them computer balanced and a reputable tire dealer. Often you can get a deal on lifetime balancing and rotation.
    If it is indeed related to the propeller shaft the need for replacement is extremely rare unless the shaft itself has been damaged. If your tires check out okay, then the rear shaft would be the best place to start troubleshooting. You want to check your universal joints for play and make sure they're properly lubricated. There's also grease zerk at the spline coupling that needs to regularly lubricated as well. Also, driveshafts can be balanced. So if you simply can't find an obvious problem go to a reputable driveshaft shop and look into getting the shaft balanced which is simple and far less expensive than replacement.
    Sep 2006
    2000 Black VX 0223
    Thanks for the info. The tires were just balanced, but I will look at the u-joints.
    Nov 2002
    Arrow
    Don't overlook the tires because they were just done. The shop could have done them improperly, a balancing weight may have shifted or even slung off. Have them re-check the balance as you don't want to leave any possibility unexplored, and the tires are the easiest to verify.
    Sep 2006
    2000 ebony 0243
    try
    google pams parts inc or pams auto part they usually have a vx around have a 99 right now that has a lot of pts
    good luck
    Oct 2004
    2001, ebony, VX, 0982
    Same Here
    I too am experiencing the same thing. it shows up very very little around 50 mph then not again till 82mph threw 85mph, but from 85-90 it quiets down but then from 90-94mph it comes back again? I've had this problem for 30000 miles now it has never gotten worse but i'm sick of it. Any more suggestions joe?
    2001 Proton VX 0790
    I am chasing the same speed sensitive vibration. I feel it through my feet and not as feedback in the steering wheel.
    I know its not tires in my case because I have 2 sets of rims/tires. both have been checked for balance and the rims are straight. I'm also sure its not belt shift.
    So far I have replaced the front wheel bearings and seen no change. It feels like its cv joint shaking, but with the wheel jacked up I can't find slop in the joint.
    My next step will be to put the truck on 4 jackstands and run it. Hopefully I can see whats shaking.
    John C.
    Nov 2002
    Arrow
    Quote Originally Posted by Hotsauce
    See if you can put it on a lift at a shop rather than the jackstands, that's a sure fire way to get into the next Darwin Award list.
    Also, with the suspension dropped to full extension without any load you're radically changing "driving" conditions which may be causing the vibration.
    Take some time and a flashlight to visually inspect both driveshafts for damage or the tell-tale sign of missing balance weights. Do the same for your wheels inside and out, and even look at the brake rotors.
    Oct 2004
    Question found the culprit?
    well I checked the driveshafts and what I think is the u-joint (long u shaped shaft, above the ear axel running the width of the car?) The rear driveshaft is solid as a rock, I was yanking on it, and no give. However, the front shaft will wobble a little bit with just minemal effort. I'm guessing around 1, maybe 2/16 of slop. Is this this the coulpret? Can I clean that slop up myself? Where do I go from here? thanks tom
    Oct 2004
    anyone still listening?
    if anyone has some imput on where I should go from here I would greatly appreciate it
    The u-joints are mounted at the ends of the driveshafts - they are the "joints" that connect the driveshafts to the axles and the transfer case. They are small (4" crosses) - if your front driveshaft is wobbling then you quite possibly do have a bad u-joint or two in that shaft. Those u-joints would need to be removed and tossed so some new ones can be installed. If the vibration hasn't gotten worse in 30,000 miles though I would say you have another issue. Don't know what, however.
    I think what you described, "long u shaped shaft, above the ear axel running the width of the car" sounds like the rear anti-sway bar - I don't know what else it could be off-hand... but if you misidentified an anti-sway bar as a u-joint you might want to have someone else work on the problem for you... no offense.
    Oct 2004
    gotcha
    no offense taken, lol yea that was the sway arm. how much do ujoints run? two fronts and how long does the process take to swap em out? also, should there be some slop in that shaft? help
    I have never bought a u-joint for the VX but for a Jeep the range from like $8 to $20 or so. I haven't checked our driveshafts to see how the u-joints are secured yet. Some vehicles have them pressed in, some use u-bolts, some use straps and bolts. It should be a fairly quick procedure on any type - less than an hour to fit new joints to each shaft... at least in my experience. I have done minimal work to my VX thus far. After this weekend though I might have some better answers!
    Oh, the slop you speak of... I would say there shouldn't be any slop - but again, I haven't worked on mine much and it may be typical. Hope I helped.
  1. Front drive shaft
    Last Post: 02/17/2017, 07:02 PM
  2. front drive shaft
    Last Post: 02/01/2015, 12:41 PM
  3. Front drive shaft help
    By cheetah2390 in forum VX Troubleshooting...
    Last Post: 05/22/2014, 04:57 PM
  4. ABS and drive shaft U joints
    By kitman3 in forum VX Troubleshooting...
    Last Post: 10/23/2013, 11:03 PM
  5. Drive Shaft Rebuilding
    By blacksambo in forum VX Troubleshooting...
    Last Post: 12/03/2011, 11:27 PM
