Results 1 to 15 of 20
Thread: Getting Windows fixed
    Feb 2004
    01, Silver, 0603
    First of all, let me say I'm in Iraq and my VX is in Hawaii, so I won't be fixing it myself. Before I left both windows began slowing, and then the dreaded canting. How much is it going to cost to fix? I know there will be + or - $$$, but am I looking at $50 or $500.
    I should have seen it coming. The cd player went a while ago. I was going to sell it, but then I look at pics of it and come to my senses.
    '99 Ebony VX #0038
    Sorry to say, it's hit or miss with those windows. Even the dealership doesn't have a solid solution that always works. A few members here have found various solutions, but none that work universally. If you do a search here you will find countless threads discussing your options.
    Dec 2003
    Former Owner 0216
    Yep. Not sure if there is a permanant fix, as mine are dying AGAIN!!!
    Mar 2006
    2001 FOXFIRE 0579
    heyctp,
    i noticed on my, as others may have, that when i did the window fixes, (all of them on mine,3 i think,) that the slowing that i noticed was not to bad once the window was lined up properly. guys, is it safe to say initally, that the slow window doesnt mean the motor is trash yet?? to do all the mods on the window, i think i spent less than 6 bucks, and that included a new dremell bit. all said, id do the window fixes first, befor having a buddy buy a new motor. if you want to send me to your place, i will fix it for you ........should only take about a week and a half two tops !!! lol
    thank you for your work over there,
    God bless,
    david
    2001,FOX FIRE RED MICA,0251
    Window Fix
    All I Do Is Spray Silicone Lube On The Side Tracks From Top To Bottom Every So Often And They Work Great,no More Tipping Foward And Dragging,they Work Like Brand New And When I Bought It They Hardly Moved Up Cause The Rubber In The Track Was Dry And Would Cause The Window To Tip And Stick.easy Fix No Modifications Needed.
    Hey Willy,
    Mine are getting pretty slow too, were can I get silicone lube? And what brand do you use? Is this something I can get at Home Depot? Also, where exactly do you spray it?
    Thanks - Bart
    Quote Originally Posted by WILLY
    2001, Ebony Black, 1153
    Silicone Spray
    I got my Silicone Spray at AutoZone for $3, pepboys did not have any.
    2000 IronMan #11
    IndianaVX
    I am in IN as well, are you serious you can really fix the windows?
    WILLY;LittleBeast
    What ecattly is this lube and how do you exactally apply it. Thanks
    '99 Ebony VX #0038
    Quote Originally Posted by IndianaVX
    i noticed on my, as others may have, that when i did the window fixes, (all of them on mine,3 i think,) ...should only take about a week and a half two tops !!! lol...
    Quote Originally Posted by JHarris1385
    IndianaVX
    Sure, he'll do all three of them and they'll only take two weeks!
    Silicone It
    I Use Crc Heavy Duty Silicone Spray From Wal-mart In The Lubricant Isle In Automotive Right By The Wd-40 Its In A Red And White Can $1.77.just Spray It On The Side Tracks Where The Edges Of The Window Run,use The Little Stick That Comes With It,some Will Get On The Window But Wipes Right Off With No Goobery Oily Stuff.spray It With A Good Amount The First Couple Times To Git Things Lubed Up And Then Run Ur Windows Up And Down And It Will B Like Magic,then When U Start To Notice Them Slowing Again Spray Them Again,u Will Probably Have To Do It Once A Month Or So Depending On Temp Conditions Outside,and Winter They Will Run A Little Slower Cause Cold Air Makes Things Expand There For Causing Friction So U Will Have To Keep Lubed More Often Maybe In The Winter If U Have Winter Where U Live Lol.
    Silicone It
    O U WILL HAVE TO HAVE THE DOOR OPEN AND THE WINDOW ALL THE WAY DOWN WHEN U SPRAY UR SIDE TRACKS.
    Jun 2005
    2001 Black VX
    I Love That You Are Capitalizing The First Letter Of Every Word. Thats Funny. But Makes It Harder To Read.
    '99 Ebony VX #0038
    Actually When Its Cold Outside Liquids Expand Because They Freeze But Things Like Metals Actually Contract But Your Rite Because The Silicon Lubricant Spray Will Flow Slower In The Winter And Just For The Record They Have Winter Everywhere Because The Earth Orbits The Sun On A Tilted Axis Which Alters The Angle At Which Sunlight Reaches Different Parts Of The Planet During Different Times Of The Year Which Changes Its Intensity Giving Us What We Perceive As Different Seasons But Depending On How Close To The Equator You Are It May Or May Not Be A Dramatic Difference From One Season To The Next lol.
    U guyS arE funnY
    2000 IronMan #11
    Quit with the caps......Its like your starting a sentence with every word. Ha ha
  1. Windows Binding Problem Fixed for $3 in 3 minutes
    By Bill Brown in forum General Tips...
    Last Post: 02/10/2016, 02:56 PM
  2. Fixed my window
    By SomeBeach in forum VX Talk...
    Last Post: 06/29/2009, 06:23 AM
  3. For those that fixed windows
    By ctp in forum VX Troubleshooting...
    Last Post: 02/06/2009, 06:04 AM
  4. I finally fixed my windows!!!
    By jdm monkey in forum VX Troubleshooting...
    Last Post: 08/10/2008, 07:54 AM
  5. windows fixed under warranty
    By ocwiley in forum VX Talk...
    Last Post: 11/18/2003, 07:17 PM
