Results 1 to 5 of 5
Thread: ABS Light and Warranty
    2001, Ebony
    Does anyone know if the ABS light issue is covered under warranty? The ABS light goes on and off randomly. I've done a search and it looks like it will cost over a thousand to have that part fixed by the dealer. When I bought my car in 02 I bought an extended warranty. 5yrs / 100k miles $50 deductable. So, my warranty runs out in April of 07. Is this covered by the warranty?
    Jun 2005
    01 Dragon Green VX 1286
    I would think so... check the waranty paperwork.. or call the issuer of the waranty (sic)
    Jeff
    Thanked: 7
    Post
    Make sure you know what exactly is out in the ABS system. A few that I know of are: A sensor could be out, or the ABS hydraulic module is out or the ABS control component of the ECM isnt working, or just the ABS fuse. You are pretty knowledgeable with the VX so maybe you have it pinned down already. Depending on which part may mean warranty or no warranty.
    I know when my hydraulic module went out it was not covered under my Isuzu warranty, your coverage may be different.
    ECM and hydraulic module are expensive new but much cheaper used. Car-parts.com
    Anita
    2000 Ebony #263
    AnitaProtich.com
    2001, Ebony
    How would I find out what the ABS Light code is? Should I have Pep Boys plug in their hand held and tell me what the code means?
    2001, Proton Yellow, #0580
    It should produce a code when checked with an ODBII reader. Try Pep Boys and see if it will display a number, then cross-check with your manual.
    -- John
  1. Help with wiring light acces. to dome light
    Last Post: 11/24/2013, 09:49 PM
  2. Warranty ?
    By AndyC in forum VX Talk...
    Last Post: 04/19/2012, 07:47 AM
  3. Rear cargo light + underhood light
    Last Post: 05/29/2010, 09:00 AM
  4. spoiler tail light / hazard light question !
    By Spike in forum VX Talk...
    Last Post: 05/21/2007, 09:27 PM
  5. Dead short in Rear Light/Instrument light
    By Damien Jones in forum VX Troubleshooting...
    Last Post: 07/16/2006, 08:49 PM
