Results 226 to 240 of 407
Thread: Post of all Rims and Tires out there!
Threaded View
    Nov 2002
    2001 Dragon #0467
    The thread for AFTERMARKET WHEELS and TIRES for the VX.
    Please post pictures if you have upgraded your VX with AFTERMARKET WHEELS and TIRES.
    So we can have a reference of what looks good!
    So please post a picture along with these specs.
    Rims are: (brand/size/offset)
    Tires are: (brand/size/overall diameter)
    Stock height or Lifted (if Lifted, please list Lift specs)
    Note any trimming.
    Let me know if I need to change any specs.
    Thanks for everyone's help.
    rickshaw
    Rims and Tires Part 2
    Rims and Tires Part 3
    Rims and Tires Part 4
    Rims and Tires Part 5
    Rims and Tires Part 6
    Rims and Tires Part 7
    Rims and Tires Part 8
    Rims and Tires Part 9
    Rims and Tires Part 10
    Rims and Tires Part 11
    Rims and Tires Part 12
    Rims and Tires Part 13
    Useful Links:
    Wheel Spec Wiki Thread
    Before and After Thread
    Tire Size Calculator
    Wheel Offset Calculator
    Wheel/Tire Comparer
    Offset to Backspacing Chart
    How to Post a Picture
    Stock VX wheel & Tire Specs for reference
    245/60-18 Bridgestone Dueler (Diameter 29.6 in)
    18x7 and 16x7 (38mm positive offset) 6X139.7mm or 6x5.5" Bolt Pattern
    Rims & Tires Part 1
    rickshaw
    Rims are KMC XD Monster 18x9 (Offset +18mm) (Back Spacing 5.71in) (Center Bore 106.25mm)
    Tires are Nitto Terra Grapplers 285/60/18 (Diameter 31.38 in)
    (Lifted) OME 913's, 2" torsion bar crank
    Rickshaw's Mod Thread
    More info on the 913's
    Jay Dunford
    Rims are Mickey Thompson Classic Locks in 16x8
    Tires are Goodyear MTR 305/70/16. (Diameter 32.8 in)
    (Lifted) OME 912's + 1" poly spacers for a 3-1/2" lift in the rear; crank the torision bars + 1/4" ball joint spacers to level the front.
    Kenny
    Rims are 17x8 Enkei RT6 rims (0 offset, 4.5 Backspace)
    Tires are Mickey Thompson BAJA MTZ 265/70/17(Diameter 31.6 in)
    (Lifted)
    Kenny's Tire Thread
    Pho2gr4
    Rims are 16x8 American Racing Teflon Chambers wheels. ("0" Offset 4.5" Backspace)
    Tires are 275/70/16 Yokohama's (Diameter 31.2 in)
    (Lifted) OME 913's
    Dumke
    Rims are American Racing ATX Thugs 18x9 ("0" Offset 5" Backspace)
    Tires are Nitto Terra Grapplers 285/65/18 (Diameter 32.6 in)
    (Lifted) Independent 4x premium lift kit
    Dumke's Wheels & Tires Thread
    Zues
    Rims are BBS Moda R7 18x8.5 (Offset "0")
    Tires are 275/65/18 Hankook Dynapro mud tires (Diameter 32.1 in)
    (Lifted)
    LittleBeast
    Rims are Zinik Z26 20x8.5 (Offset +15mm)
    Tires are 33x12.5 Nitto Mud Grapplers (Diameter 32.95 in)
    (Lifted) OME 912 springs, ball joint flip, and torsion crank
    LittleBeast's Build Up Thread
    Ldub
    Rims are 20x8" Centerline Tomahawk Rapid (polished)
    Tires are 33-12.50x20" Nitto Mud Grapplers
    (Lifted) Lift: 3-4" (OME 919's, 1" coil spacer & T-bar crank)
    taylorRichie
    Rims are KMC Rockstar 20X8.5 (Offset +10mm)
    (Lifted) OME912 Coils, +1" Spacer, Torsion Crank, Lots o' Trimmin'
    taylorRichie's Build Up Thread
    Rowhard
    Rims are MKW M18 18x8.5 (Offset +18)
    Tires are Toyo Open Country AT 285/60R18 (Diameter 32.6 in)
    (Stock height) Bars cranked to get some extra clearance plus trimming
    JoFotoz
    Rims are Pro Comp "Street Lock" 16x8 MT Classic Lock simulate #MT 468412
    Tires are 33x11.50x16 Nitto Mud Grapplers
    (Lifted) 3 inch Calmini lift.
    nfpgasmask
    Rims are 16" American Racing Chambers w/Teflon
    Part number: AR3985-6883 (0 offset/4.5 on the backside)
    Tires are 265 75/R16 (Diameter 30.7 in) BFG Mud Terrains
    (Lifted)
    nfpgasmask's Rims Thread
    CrnCnn
    Rims are Crager Soft 8 16x8 (5" backspace +12mm offset)
    Tires are BFGoodrich All-Terrain T/AŽ KO 245/75/16 (Diameter 30.5 in)
    (Lifted) OME 912's
    CrnCnn's Build Up Thread
    Jolly Roger VX'er
    Rims are 16"X 8" American Racing "Breaker" chromed aluminum wheels w/ 12mm of offset
    Tires are 265-75-r16 (32" tall) Green Diamond Icelander M/T's (Severe Snow Rated)
    (Lifted) Two-inch rear coil spring spacers from Independent4X.com plus 8 cranks each side on front Torsion bars.
    Swordy
    Rims are 16" (need more info)
    Tires are 33x12.50x16's Parnelli Jones dirt gripz (Diameter 33.3)
    (Lifted) 3" Calmini lift
    Daver
    Rims are OZ Crono 4x4 16x8 (Offset +10)
    Tires are BFGoodrich All-Terrain T/AŽ KO 265/70-16 (Diameter 30.6 in)
    (Stock height) Trimed the front fender a little bit.
    More Info Here
    tom4bren
    Rims are (need more info)
    Tires are 33x12.50 Goodyear Wrangler
    (Lifted)
    dstruction
    Rims are Dante 20 inch wheels
    Tires are 36 inch super swamper IROKs
    (Lifted)
    Cyrk
    Rims are 18x8 Borbet CW3 (Chrome
    Tires are Toyo Proxes S/T Tires 255/55/18 (Diameter 29.0 in)
    (Stock height)
    For more pics on see post #23
    BaM*BaM
    Rims are Silver 18x8 Borbet CW3
    Tires are 35x12.50x18 BFGoodrich Mud-Terrain T/A
    (Lifted)
    rickshaw
    2001 Dragon #0467
  1. Replies: 11
    Last Post: 11/05/2012, 01:22 PM
  2. Post of all Rims and Tires out there!
    By rickshaw in forum VX Modifications...
    Last Post: 12/03/2010, 08:52 PM
  3. Like these rims/tires?
    Last Post: 10/20/2010, 07:01 PM
  4. Rims and Tires
    By Dean Brown in forum VX Modifications...
    Last Post: 03/03/2009, 10:25 PM
  5. New Rims Need New Tires
    By UNEVEN THOUGHTS in forum VX Modifications...
    Last Post: 01/10/2005, 09:12 PM
